[GRASS-dev] compila grass on fedora31: configure: error: *** Unable to locate GDAL library.
    Veronica Andreo
    veroandreo at gmail.com
    Mon Nov 11 04:31:17 PST 2019
I had the same issue last week in an Ubuntu 18 box, both installing
binaries and trying to compile grass. We had to remove everything, esp the
official repo of qgis, install grass first from ubuntugis-unstable and then
get an older qgis version. Some dependencies hell and conflicting versions,
I guess...
Did you try installing from binaries? There's already grass7.8.1 for f31:
https://koji.fedoraproject.org/koji/buildinfo?buildID=1410936
Vero
El lun., 11 nov. 2019 a las 9:13, Pietro (<peter.zamb at gmail.com>) escribió:
> Dear devs,
> I have an issue when* I* try to configure ad compile grass.
> At the moment I'm on Fedora 31. So I installed the default gdal (2.3.2)
> with:
> `sudo dnf install gdal gdal-devel gdal-libs`
> I executed locally gdalinfo on a tif and it provide the information of the
> raster and then I checked the installation paths with:
> $ /usr/bin/gdal-config --version
> 2.3.2
> $ /usr/bin/gdal-config --libs
> -L/usr/lib64 -lgdal
> $ /usr/bin/gdal-config --cflags
> -I/usr/include/gdal
> $ /usr/bin/gdal-config --datadir
> /usr/share/gdal
> So it seems to work, then my configure command is:
> $ CFLAGS="-g -O1 -Wall -Wextra -Wundef -Wfloat-equal -Wpointer-arith
> -Wcast-align -Wstrict-prototypes -Wstrict-overflow=5 -Wwrite-strings
>  -Wshadow -Werror-implicit-function-declaration -Waggregate-return
> -Wcast-qual -Wswitch-default -Wswitch-enum -Wconversion -Wunreachable-code
> -Winit-self -Wuninitialized -fno-common -fexceptions -fstack-protector
> -fmudflap -m64 -mtune=native" \
> CXXFLAGS="-g -O1 -Wall" \
> ./configure \
>     --prefix=$HOME/.local \
>     --with-zstd \
>     --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
>     --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
>     --with-cxx \
>     --with-cairo \
>     --with-freetype \
>     --with-freetype-includes=/usr/include/freetype2 \
>     --with-geos \
>     --with-gdal=/usr/bin/gdal-config \
>     --with-gdal-includes=/usr/include/gdal \
>     --with-gdal-libs=/usr/lib64 \
>     --with-gdal-share=/usr/share/gdal \
>     --with-nls \
>     --with-netcdf \
>     --with-odbc \
>     --with-openmp \
>     --with-postgres \
>     --with-python=/usr/bin/python3-config \
>     --with-readline \
>     --with-proj \
>     --with-pthread \
>     --with-sqlite \
>     --with-wxwidgets=/usr/bin/wx-config
> But I get the following error:
> checking host system type... x86_64-pc-linux-gnu
> checking for gcc... gcc
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/bin/gdal-config
> Do you understand why I still receive this error even if I specify all the
> paths of the gdal iclude/libs/share directories?
> Any ideas on how to solve/fix this issue?
> Thank you for your support.
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191111/9ca0bcc5/attachment-0001.html>
