[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Markus Neteler neteler at osgeo.org
Wed Nov 13 06:38:47 PST 2019
On Wed, Nov 13, 2019 at 3:27 PM Pedro VenĂ¢ncio
<pedrongvenancio at gmail.com> wrote:
> Hi all again,
> I've tested GRASS standalone and I got the same error with WinGRASS-7.8.1-1-Setup-x86_64.
> Then I uninstalled this version and installed WinGRASS-7.8.0-2-Setup-x86_64 and everything worked fine.
> So, it seems that there is something wrong with GRASS-7.8.1 in my machine. Also when running algorithms in CLI, GRASS throws the message about gdal300.dll, but that dll is present in the path specified (screenshot attached).
> Any hint about what can be wrong?
Probably this recent fix is needed?
  https://github.com/OSGeo/grass/pull/191
It will be part of 7.8.2.
Best regards,
Markus
