[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Markus Metz markus.metz.giswork at gmail.com
Wed Nov 13 07:02:58 PST 2019
On Wed, Nov 13, 2019 at 3:39 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Nov 13, 2019 at 3:27 PM Pedro VenĂ¢ncio
> <pedrongvenancio at gmail.com> wrote:
> > Hi all again,
> > I've tested GRASS standalone and I got the same error with
WinGRASS-7.8.1-1-Setup-x86_64.
> > Then I uninstalled this version and installed
WinGRASS-7.8.0-2-Setup-x86_64 and everything worked fine.
> > So, it seems that there is something wrong with GRASS-7.8.1 in my
machine. Also when running algorithms in CLI, GRASS throws the message
about gdal300.dll, but that dll is present in the path specified
(screenshot attached).
> > Any hint about what can be wrong?
> Probably this recent fix is needed?
>   https://github.com/OSGeo/grass/pull/191
No, because GRASS is actually looking for gdal300.dll.
Looks like a packaging error in WinGRASS-7.8.1-1-Setup-x86_64, if others
can confirm this.
Markus M
> It will be part of 7.8.2.
> Best regards,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191113/6ff3731b/attachment.html>
