[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Pedro Venâncio pedrongvenancio at gmail.com
Thu Nov 14 03:54:04 PST 2019
Hi Markus and Markus,
I hope someone else can test, because here in my machine:
- GRASS 7.8.1 standalone 64bits does not work;
- GRASS 7.8.0 standalone 64bits work fine;
- GRASS 7.8.1 from OSGeo4W64 does not work, also inside QGIS;
- GRASS 7.8.0 from OSGeo4W64 does not work, also inside QGIS;
- GRASS 7.8.1 installed with QGIS 3.4.13-2 and QGIS 3.10.0-2 does not work,
also inside QGIS;
- GRASS 7.6.1 installed with QGIS 3.4.13-1 and QGIS 3.10.0-1 work fine,
alone and inside QGIS.
In all of them, when I try to run any GRASS algorithm from grass78 --text,
I get the gdal300.dll error.
Best regards,
Pedro
Markus Metz <markus.metz.giswork  gmail.com> escreveu no dia quarta,
13/11/2019 à(s) 15:03:
> On Wed, Nov 13, 2019 at 3:39 PM Markus Neteler <neteler  osgeo.org> wrote:
> > On Wed, Nov 13, 2019 at 3:27 PM Pedro Venâncio
> > <pedrongvenancio  gmail.com> wrote:
> > > Hi all again,
> > > I've tested GRASS standalone and I got the same error with
> WinGRASS-7.8.1-1-Setup-x86_64.
> > > Then I uninstalled this version and installed
> WinGRASS-7.8.0-2-Setup-x86_64 and everything worked fine.
> > > So, it seems that there is something wrong with GRASS-7.8.1 in my
> machine. Also when running algorithms in CLI, GRASS throws the message
> about gdal300.dll, but that dll is present in the path specified
> (screenshot attached).
> > > Any hint about what can be wrong?
> > Probably this recent fix is needed?
> >   https://github.com/OSGeo/grass/pull/191
> No, because GRASS is actually looking for gdal300.dll.
> Looks like a packaging error in WinGRASS-7.8.1-1-Setup-x86_64, if others
> can confirm this.
> Markus M
> > It will be part of 7.8.2.
> > Best regards,
> > Markus
> > grass-dev mailing list
> > grass-dev  lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191114/218d8442/attachment.html>
