[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Helmut Kudrnovsky hellik at web.de
Fri Nov 15 15:30:10 PST 2019
>Do you see anything suspicious?
Nothing obvious
>The message I get (screenshot attached) is something like "It was >not
possible to find the entry point of the procedure curl_mime_init >in the DLL
C:\OSGEO4~1\bin\gdal300.dll".
ok, I think we're narrowing down the issue now.
I've seen there was a curl update today in OSGeo4W 64bit. please try to
update your OSGeo4W environment and try again to start winGRASS in OSGeo4W.
Otherwise, open a ticket in OSGeo4W for the gdal curl issue.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
