[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Pedro Venâncio
pedrongvenancio at gmail.com
Fri Nov 15 16:38:57 PST 2019
I've seen there was a curl update today in OSGeo4W 64bit. please try to
> update your OSGeo4W environment and try again to start winGRASS in
> OSGeo4W.
Updated now, but same error when running any algorithm.
Also when starting the gui I get
C:\OSGeo4W64\bin>g.gui
Launching <wxpython> GUI in the background, please wait...
C:\OSGeo4W64\bin>Traceback (most recent call last):
File "C:\OSGEO4~1\apps\grass\grass78/gui/wxpython/wxgui.py", line 107, in
OnInit
workspace=self.workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\lmgr\frame.py", line
143, in __init__
self.notebook = self._createNoteBook()
338, in _createNoteBook
gcstyle=GC_PROMPT)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\gui_core\goutput.py",
line 118, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\gui_core\prompt.py",
line 138, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
line 56, in __init__
self.mapList = self._getListOfMaps()
line 100, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\script\core.py",
line 1288, in list_strings
mapset=mapset).splitlines():
line 503, in read_command
return handle_errors(returncode, stdout, args, kwargs)
line 343, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None g.list --q -m
type=raster ended with error
Process ended with non-zero return code 3221225785. See errors in the
(error) output.
OnInit returned false, exiting...
Error in atexit._run_exitfuncs:
wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this" failed
at ..\..\src\common\wincmn.cpp(478) in wxWindowBase::~wxWindowBase(): any
pushed event handlers must have been removed
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/ed00b2fc/attachment.html>
