>Updated now, but same error when running any algorithm. Search in the log files for curl and similar and look which library uses curl, then repeat where in the OSGeo4W shell and a normal Windows cmd line with this library name ----- best regards Helmut -- Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
