[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Jürgen E. Fischer jef at norbit.de
Sat Nov 16 06:22:32 PST 2019
Hi Helmut,
On Sat, 16. Nov 2019 at 01:21:03 -0700, Helmut Kudrnovsky wrote:
> >Updated now, but same error when running any algorithm.
> Search in the log files for  curl and similar and look which library uses
> curl,  then repeat where in the OSGeo4W shell and a normal Windows cmd line
> with this library name
That update is unrelated.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/2899fde7/attachment.sig>
