[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
    Pedro Venâncio
    pedrongvenancio at gmail.com
    Sat Nov 16 15:06:58 PST 2019
Hi Helmut,
checking here:
> QGIS version 3.10.0-A Coruña
> Compiled against Qt 5.11.2
> Compiled against GDAL/OGR 3.0.2 <=
> Compiled against GEOS 3.8.0-CAPI-1.13.1
> Compiled against SQLite 3.29.0
> PostgreSQL Client Version 11.5
> 3.10.0 is now available in OSGeo4W without the need to install gdal-dev
I'm using nightly builds (qgis-rel-dev), and this one needs gdal-dev.
QGIS code revision 1ffa829539
Compiled against GDAL/OGR 3.1.0dev
Running against GDAL/OGR 3.1.0dev
> I compared your explorer search results here with mine on a windows 10 box.
> in
> https://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0005.jpg
> there are 2 libcurl.dlls from 2016.
> I don't have them in my win 10 box. not sure if you have admin rights on
> your box, but you can rename them and then try to start winGRASS again.
Perfect!!! These libcurl.dlls were the problem! More precisely, the one on
System32. After changed their names, everything works again! Issue solved!
Thank you very very much for your help and persistence Helmut!
Best regards,
Pedro Venâncio
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/e77bbd2e/attachment.html>
