[GRASS-dev] [GRASS GIS] #3980: Error Reading list of LiDAR files in r.in.lidar 7.6.1, 7.8.1 on Windows 10
GRASS GIS trac at osgeo.org
Tue Nov 26 07:49:35 PST 2019
  Reporter:  dnewcomb  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.8.2
 Component:  Default   |    Version:  git-releasebranch78
Resolution:            |   Keywords:  Python input file list
       CPU:  x86-64    |   Platform:  MSWindows
Comment (by dnewcomb):
 Checking back,  running from the command line and not the GUI resulted in
 successful completion of the command for 1870 tiles on Windows.  I can
 confirm that the errors above  seem to be related to just the gui.
 One side note, instead of seeing a standard percent completion updated for
 the duration of the command, a repeating 100% was printed while the
 command was processing.  I assume that it was reporting 100% as each tile
 was completed?
 The raster product appears to have been created successfully.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3980#comment:4>
