[GRASS-dev] [GRASS GIS] #3980: Error Reading list of LiDAR files in r.in.lidar 7.6.1, 7.8.1 on Windows 10
trac at osgeo.org
Tue Nov 26 14:05:16 PST 2019
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.2
Component: Default | Version: git-releasebranch78
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows
Changes (by wenzeslaus):
* keywords: Python input file list =>
Comment:
Replying to [comment:4 dnewcomb]:
> Checking back, running from the command line and not the GUI resulted
in successful completion of the command for 1870 tiles on Windows. I can
confirm that the errors above seem to be related to just the gui.
Can you perhaps close this one as invalid and, if you can reproduce it,
create a new one with steps how to reproduce it (and link it here).
> One side note, instead of seeing a standard percent completion updated
for the duration of the command, a repeating 100% was printed while the
command was processing. I assume that it was reporting 100% as each tile
was completed?
Makes sense. You can create a ticket for that.
Replying to [comment:3 marisn]:
> Check the version of libLAS as there where bugs in its C API causing
segfaults:...
Thanks for the update and the PR too!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3980#comment:5>
