[GRASS-dev] compilation ready docker image
andrea antonello
andrea.antonello at gmail.com
Tue Oct 15 23:15:44 PDT 2019
Hi Markus,
>> I am wondering if one of the available docker for GRASS are
>> compilation ready, i.e. if they have everything necessary to be used
>> as a base to copy in a module, compile it and happily use the whole
>> thing.
> I'd say yes.
> You can also install Addons therein which requires that.
ah, I was missing the fact that addons are compiled in when installed.
> In case of troubles let me know.
Thank you,
Andrea
> Best
> Markus
>> Thank you,
>> Andrea
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
