[GRASS-dev] compilation ready docker image
andrea antonello andrea.antonello at gmail.com
Tue Oct 15 23:28:47 PDT 2019
Ok, some troubles right away :-)
Some context first, since maybe there is a better way to handle this.
I would like to make some users test r.avaflow. Some of them are also
on windows (hence the idea to use docker).
The first burden I see is that the latest version of avaflow
apparently depends on python 2.7 (as of the install script):
PATHPYTHON="/usr/lib/python2.7/"
Looking at the docker images it seems that I will have to use the old
stable from releasebranch_7_6, right?
I was hoping to be able to use an alpine based version, do you know of
any image available?
Thansk,
Andrea
On Wed, Oct 16, 2019 at 8:15 AM andrea antonello
<andrea.antonello at gmail.com> wrote:
> Hi Markus,
> >> I am wondering if one of the available docker for GRASS are
> >> compilation ready, i.e. if they have everything necessary to be used
> >> as a base to copy in a module, compile it and happily use the whole
> >> thing.
> > I'd say yes.
> > You can also install Addons therein which requires that.
> ah, I was missing the fact that addons are compiled in when installed.
> > In case of troubles let me know.
> Thank you,
> Andrea
> > Best
> > Markus
> >> Thank you,
> >> Andrea
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/grass-dev
