[GRASS-dev] [release planning] GRASS GIS 7.8.0 with Python3 support
Markus Neteler neteler at osgeo.org
Thu Sep 5 03:54:36 PDT 2019
On Thu, Sep 5, 2019 at 12:48 PM Sebastiaan Couwenberg
<sebastic at xs4all.nl> wrote:
> On 9/5/19 12:15 PM, Martin Landa wrote:
> > čt 5. 9. 2019 v 11:56 odesílatel Sebastiaan Couwenberg
> > <sebastic at xs4all.nl> napsal:
> >> There is still an issue with g.extension using svn export in
> >> download_source_code_official_github():
> >>  https://github.com/OSGeo/grass/blob/releasebranch_7_8/scripts/g.extension/g.extension.py#L1094
> >> REQUIREMENTS.html also only documents git as a dependency for g.extension:
> > that's wrong, g.extension is using 'svn export' (for official repo).
> Using `svn export` for git repositories makes no sense/is a horrible hack.
> >>  https://github.com/OSGeo/grass/blob/releasebranch_7_8/REQUIREMENTS.html#L210
> >> But g.extension also uses svn in download_source_code_svn():
> >>  https://github.com/OSGeo/grass/blob/releasebranch_7_8/scripts/g.extension/g.extension.py#L1066
> > download_source_code_svn() is used only when source is 'svn' [1].
> > Let's imagine that user/company has own repository with addons
> > maintained by svn.
> Hence the need for REQUIREMENTS.html to list both git & subversion for
> g.extension.
Yes, to be changed.
> > Note that for 'official' source (which is now
> > https://github.com/osgeo/grass-addons) [2] is used
> > download_source_code_official_github() which is based on 'svn export'
> > instead of 'git' [3]. With git the whole repository would need to be
> > cloned with full history and all addons modules. That's something we
> > would like to avoid. With github 'svn export' trick do the job. Only
> > single addons (directory) [which is requested by the user to be
> > installed] can be fetched. I hope that we will find better solution in
> > the future.
> As mentioned in the thread on the pkg-grass-devel lists [0], use shallow
> clone.
> [0]
> https://alioth-lists.debian.net/pipermail/pkg-grass-devel/2019-August/079643.html
this is unclear to me:
Would shallow clone not clone the entire repo?  But we only want a
subdirectory out of it.
Best
Markus
