[GRASS-dev] [GRASS GIS] #3737: Testsuite gunittest/multirunner.py: TypeError: str expected, not bytes
trac at osgeo.org
Fri Sep 6 13:18:12 PDT 2019
Reporter: AnikaBettge | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python | Version: git-releasebranch78
Resolution: | Keywords: Python3, testsuite
CPU: x86-64 | Platform: Linux
Changes (by neteler):
* version: svn-trunk => git-releasebranch78
Comment:
State as of today:
g.version -rge
version=7.8.dev
date=2019
revision=726b55ea2
build_date=2019-09-06
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=00000
libgis_date="?"
proj4=5.2.0
gdal=2.3.2
geos=3.7.1
sqlite=3.26.0
bash test_framework_GRASS_GIS_with_NC.sh
test_framework_GRASS_GIS_with_NC.conf
--2019-09-06 22:11:34--
http://fatra.cnr.ncsu.edu/data/nc_spm_full_v2alpha.tar.gz
Resolving fatra.cnr.ncsu.edu (fatra.cnr.ncsu.edu)... 152.1.72.43
Connecting to fatra.cnr.ncsu.edu (fatra.cnr.ncsu.edu)|152.1.72.43|:80...
connected.
HTTP request sent, awaiting response... 416 Requested Range Not
Satisfiable
The file is already fully retrieved; nothing to do.
+ echo 'Testing of GRASS GIS started: 2019-09-06-20-11'
+ '[' no = yes ']'
+ cd testreports/reports_for_date-2019-09-06-20-11
+ python
/home/mneteler/software/grass78_git/lib/python/gunittest/multirunner.py
--grassbin /home/mneteler/software/grass78_git/bin.x86_64-pc-linux-
gnu/grass78 --grasssrc /home/mneteler/software/grass78_git --grassdata
/home/mneteler/grassdata --location nc_spm_full_v2alpha --location-type nc
test_v_out_lidar from ./vector/v.out.lidar failed (2 tests failed)
decimation_test from ./vector/v.in.lidar failed (1 test failed)
test_v_in_lidar_filter from ./vector/v.in.lidar failed (1 test failed)
test_v_in_lidar_basic from ./vector/v.in.lidar failed (1 test failed)
mask_test from ./vector/v.in.lidar failed (1 test failed)
test_v_in_pdal_basic from ./vector/v.in.pdal failed (1 test failed)
test_v_in_pdal_filter from ./vector/v.in.pdal failed (1 test failed)
File "/usr/lib64/python2.7/runpy.py", line 174, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/lib64/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/etc/python/grass/gunittest/main.py", line 178, in <module>
sys.exit(main())
gnu/etc/python/grass/gunittest/main.py", line 174, in main
results_dir=results_dir)
gnu/etc/python/grass/gunittest/invoker.py", line 271, in run_in_location
gisdbase=gisdbase, location=location)
gnu/etc/python/grass/gunittest/invoker.py", line 218, in _run_test_module
stdout_file.write(stdout)
UnicodeEncodeError: 'ascii' codec can't encode characters in position
596-597: ordinal not in range(128)
+ export PYTHONPATH=/home/mneteler/software/grass78_git/dist.x86_64-pc-
linux-gnu/etc/python:
+ PYTHONPATH=/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/etc/python:
+ python
/home/mneteler/software/grass78_git/lib/python/gunittest/multireport.py
--output summary_report 'reports_for_date-*/*'
File
"/home/mneteler/software/grass78_git/lib/python/gunittest/multireport.py",
line 28, in <module>
from grass.gunittest.checkers import text_to_keyvalue
gnu/etc/python/grass/__init__.py", line 21, in <module>
_LOCALE_DIR = os.path.join(os.getenv("GISBASE"), 'locale')
File "/usr/lib64/python2.7/posixpath.py", line 70, in join
elif path == '' or path.endswith('/'):
AttributeError: 'NoneType' object has no attribute 'endswith'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3737#comment:9>
