[GRASS-dev] [GRASS GIS] #3781: v.in.geonames - fails in winGRASS7.7 (python3)
trac at osgeo.org
Fri Sep 6 13:21:20 PDT 2019
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python | Version: git-releasebranch78
Resolution: | Keywords: python3, py3
CPU: x86-64 | Platform: MSWindows
Changes (by neteler):
* version: svn-trunk => git-releasebranch78
Comment:
Tested on Linux:
wget http://download.geonames.org/export/dump/AT.zip
unzip AT.zip
v.in.geonames input=AT.txt output=at_out
Converting 52003 place names...
Scanning input for column types...
Number of columns: 19
Number of rows: 52003
WARNING: Column number 13 <admin3code> defined as string has only integer
values
WARNING: Column number 14 <admin4code> defined as string has only integer
values
Importing points...
100%
Populating table...
Building topology for vector map <at_out at user1>...
Registering primitives...
Still an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3781#comment:3>
