[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Martin Landa landa.martin at gmail.com
Sat Sep 7 11:38:53 PDT 2019
Hi Helmut,
so 7. 9. 2019 v 20:31 odesílatel Martin Landa <landa.martin at gmail.com> napsal:
> so apparently you have the same problem as me. It fails to load
> libgrass_display.7.9.dll for unknown reason. It also causes that all
> display modules fails to be compiled (or at least manual pages are not
> generated).
try to run from msys terminal (or something similar depending on your paths):
GISRC=/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass79/mswindows/osgeo4w/lib:/c/msys64/usr/src/grass79/mswindows/osgeo4w:/usr/bin:/mingw64/bin"
LC_ALL=C LANG=C LANGUAGE=C
/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/d.barscale.exe
--html-description
You will probably do not get any output or even error (which is problem).
But when you run the same command for r.info.exe, it works.
/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/r.info.exe
--html-description
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
