[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky hellik at web.de
Sat Sep 7 13:20:48 PDT 2019
Martin Landa wrote
> Hi Helmut,
> so 7. 9. 2019 v 20:31 odesílatel Martin Landa <
> landa.martin@
> > napsal:
>> so apparently you have the same problem as me. It fails to load
>> libgrass_display.7.9.dll for unknown reason. It also causes that all
>> display modules fails to be compiled (or at least manual pages are not
>> generated).
> try to run from msys terminal (or something similar depending on your
> paths):
> GISRC=/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/demolocation/.grassrc79
> GISBASE=C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32
> PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:$PATH"
> PYTHONPATH="C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
> PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass79/mswindows/osgeo4w/lib:/c/msys64/usr/src/grass79/mswindows/osgeo4w:/usr/bin:/mingw64/bin"
> LC_ALL=C LANG=C LANGUAGE=C
> /c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/d.barscale.exe
> --html-description
> You will probably do not get any output or even error (which is problem).
> But when you run the same command for r.info.exe, it works.
> /c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/r.info.exe
> --html-description
in both test cases (d.barscale.exe --html-description, r.info.exe
--html-description), I get nothing, neither an error message nor
--html-description output.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
