[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky
hellik at web.de
Sat Sep 7 12:49:03 PDT 2019
Martin Landa wrote
> Hi,
> so 7. 9. 2019 v 20:40 odesÃlatel Martin Landa <
> landa.martin@
> > napsal:
>> not sure. libgrass_display.7.9.dll is successfully built, but cannot
>> be loaded for unknown reasons. Ma
> in other words problem is not ctypes compilation, but loading
> libgrass_display.7.9.dll. It fails on different places (ctypes,
> display modules).
screening package.log, a similar OSError: [WinError 127] issue is here:
GISRC=/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/c/OSGeo4W64/bin:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w/lib:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w:/usr/bin:/mingw64/bin"
LC_ALL=C LANG=C LANGUAGE=C ./ctypesgen.py --cpp "gcc -E
-I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-I/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG" -lgrass_g3d.7.9
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/raster3d.h
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/raster3d.h
-o OBJ.x86_64-w64-mingw32/raster3d.py
-D__GLIBC_HAVE_LONG_LONG" -lgrass_arraystats.7.9
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/arraystats.h
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/arraystats.h
-o OBJ.x86_64-w64-mingw32/arraystats.py
Status: Preprocessing C:\Users\hkmyr\AppData\Local\Temp\tmplbjp8651.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
"C:\Users\hkmyr\AppData\Local\Temp\tmplbjp8651.h"
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:284,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/corecrt.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32\include\grass\dbmi.h:15,
C:\Users\hkmyr\AppData\Local\Temp\tmplbjp8651.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: 35 | #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: | ^~~~~
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:511:
Syntax error at 'va_list'Status: Preprocessing
C:\Users\hkmyr\AppData\Local\Temp\tmpmx7zuxid.h
"C:\Users\hkmyr\AppData\Local\Temp\tmpmx7zuxid.h"
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32\include\grass\raster3d.h:4,
C:\Users\hkmyr\AppData\Local\Temp\tmpmx7zuxid.h:1:
compiler
Status: Parsing C:\Users\hkmyr\AppData\Local\Temp\tmpmx7zuxid.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:79:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:157:
Status: Processing description list.
File "./ctypesgen.py", line 165, in <module>
ctypesgencore.processor.process(descriptions, options)
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\pipeline.py",
line 60, in process
find_source_libraries(data, options)
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\operations.py",
line 206, in find_source_libraries
library = ctypesgencore.libraryloader.load_library(library_name)
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\libraryloader.py",
line 258, in load_library
result = LibraryLoader.load_library(self, libname)
File
line 63, in load_library
return self.load(path)
File
line 279, in load
return _WindowsLibrary(path)
File
line 240, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 434, in
LoadLibrary
return self._dlltype(name)
File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 356, in
__init__
self._handle = _dlopen(self._name, mode)
OSError: [WinError 127] Die angegebene Prozedur wurde nicht gefunden
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
