[GRASS-dev] [GRASS GIS] #3901: Addons missing in Makefile
GRASS GIS trac at osgeo.org
Wed Sep 25 13:43:40 PDT 2019
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  unspecified
Resolution:               |   Keywords:  Makefile
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:4 sbl]:
 > Now, I updated the [https://github.com/OSGeo/grass-addons/pull/30 PR]
 so, modules with a DEPRECATED file are filtered out. I would be glad if
 someone could test it.
 Great, thanks for the re-work (didn't test yet).
 > With this change all Makefiles in raster, vector, temporal, imagery,
 general would be identical. So it is probably better to include the
 content of the Makefiles one level higher (meaning on the grass-
 addon/grass7/ hierarchy?
 ... not sure what you mean?
 > Regarding the filtering of deprecated modules: What about adding a
 deprecation warning to the manual instead of not building it? That way,
 also deprecated modules can be discovered and inspected on the addon
 manual website, but with a clear information that module ''r.in.whatever''
 has been superseded by ''r.in.newandawsome'' (or what ever the reason for
 the deprecation was)?
 I think that the overview page would become pretty cluttered. Maybe (in
 case) in a separate section but overall, it would be an extra maintenance
 burden for rather old code which if often not even any more compatible
 with the current GRASS GIS libs.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3901#comment:5>
