[GRASS-dev] Week 11 report: Creation of a new GRASS GIS startup mechanism
L.Kladivova
L.Kladivova at seznam.cz
Sun Aug 16 03:49:13 PDT 2020
Hello Community,
I am sending my report for Week 11 (August 10-August 16). The report can
also be found in the project wiki: https://trac.osgeo.org/grass/wiki/GSoC/
2020/StartupWindow .
1) What did I complete this week?
I finished implementing the very important PR which distinguishes mapsets by
ownership and lock (see https://github.com/OSGeo/grass/issues/714
(https://github.com/OSGeo/grass/issues/714), https://github.com/OSGeo/
grass/pull/849(https://github.com/OSGeo/grass/pull/849)). I also fixed a bug
that appeared when a user wanted to display a map from a different location
(see https://github.com/OSGeo/grass/issues/884
(https://github.com/OSGeo/grass/issues/884), https://github.com/OSGeo/
grass/pull/886(https://github.com/OSGeo/grass/pull/886)). Eventually, it is
not allowed to do that and a user needs to switch a mapset first.
Currently, there are 3 other PRs that are in the process:
* Start in a demo/startup location (see https://github.com/OSGeo/grass/
issues/862(https://github.com/OSGeo/grass/issues/862), https://github.
com/OSGeo/grass/issues/897, https://github.com/OSGeo/grass/pull/868
(https://github.com/OSGeo/grass/pull/868))
This issue was a bit broadened. It consists of not only creating a startup
location but also a startup mapset. This PR also gives the option to start
up whole GRASS GIS without the startup screen.
* Check for gislock and other issues when deleting/renaming/editing
mapset and location in catalog (see https://github.com/OSGeo/grass/
issues/801(https://github.com/OSGeo/grass/issues/801), https://github.
com/OSGeo/grass/pull/904(https://github.com/OSGeo/grass/pull/904))
Almost done, just some smaller cosmetic changes. This PR creates new
checking functions that check both mapsets and locations when renaming/
deleting.
* Switch to another mapset when in use (aka force remove lock) (see
https://github.com/OSGeo/grass/issues/898
(https://github.com/OSGeo/grass/issues/898), https://github.com/OSGeo/
grass/pull/906(https://github.com/OSGeo/grass/pull/906))
Almost done, this issue offers an option to force the removal of the lock
and switch to the mapset anyway.
2) What am I going to achieve for next week?
I am gonna end up those above-mentioned PRs. Then, I am gonna reflect
changes, I made in Data Catalog, in GUI.
* Reflect changes done from Data Catalog in GUI and vice versa (see
https://github.com/OSGeo/grass/issues/885
(https://github.com/OSGeo/grass/issues/885))
* when map is renamed in data catalog while it is displayed, the layer
needs to be changed otherwise rendering fails
* when map is moved elsewhere in data catalog while it is displayed
* new map is created (this item needs to be expanded, there are
multiple ways a new map is created)
* current mapset/location is changed from menu
* etc.
3) Is there any blocking issue?
No, it is not.
Any suggestions are welcome.
Regards,
Linda Kladivova
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200816/43e3853f/attachment.html>
