[GRASS-dev] Fwd: [qgis/QGIS] Can't install `qgis-plugin-grass` in Ubuntu 20.04 (#38329)
Markus Neteler neteler at osgeo.org
Wed Aug 19 12:13:56 PDT 2020
There seems to be some confusion with the Ubuntu packages, does anyone have
more insights?
And: do we need to change anything here:
https://grass.osgeo.org/download/software/linux/
Best
Markus
---------- Forwarded message ---------
Date: Mon, Aug 17, 2020 at 8:26 PM
Subject: Re: [qgis/QGIS] Can't install `qgis-plugin-grass` in Ubuntu 20.04
(#38329)
To: qgis/QGIS <QGIS at noreply.github.com>
Thanks for the hint. Note that your advice is not yet an option: Focal QGIS
packages are still absent from https://qgis.org/ubuntugis (contrary to
Bionic), while they are present only in https://qgis.org/ubuntu.
On the other hand the GRASS website's 'quick link' points to
<https://grass.osgeo.org/download/linux/> ppa:ubuntugis/ubuntugis-unstable
for installation of GRASS on Ubuntu (i.e. including Focal). There, it is at
7.8.3 (for Focal and older). In the Ubuntu Focal *universe* repository,
GRASS is at 7.8.2. Removing the PPA and re-installing GRASS from Ubuntu
Focal solved the problem.
IMHO it would be nice if GRASS would point at the requirement for GRASS to
be installed from a repository, compatible with the one holding
qgis-plugin-grass, if the latter is to be installed. In the case of Ubuntu
Focal this is not the ubuntugis-unstable PPA (yet). Suggestion @neteler
<https://github.com/neteler>
Actually not installing GRASS directly but only following the
recommendations at
https://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu to do sudo
apt install qgis qgis-plugin-grass would work and install the compatible
version of GRASS, provided that no conflicting repositories are activated
(cf. the recommendation: "Please remove all the QGIS and GRASS packages you
may have installed from other repositories before doing the update.").
However this would not yet install grass-doc and grass-gui, so to install
GRASS one still would be guided towards the PPA following the GRASS website.
You are receiving this because you were mentioned.
Reply to this email directly, view it on GitHub
<https://github.com/qgis/QGIS/issues/38329#issuecomment-675039331>, or
<https://github.com/notifications/unsubscribe-auth/AAJ4GRAYWM4EB5U2TVQXUD3SBFY6TANCNFSM4QBUB6YA>unsubscribe.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200819/2103297d/attachment.html>
