[GRASS-dev] git usage question: error: failed to push some refs...
Markus Neteler neteler at osgeo.org
Sat Aug 22 08:41:57 PDT 2020
On Sat, Aug 22, 2020 at 11:58 AM Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> I am struggling to push my code simplification (thanks for the tip,
> Vaclav) to https://github.com/OSGeo/grass/pull/922
> Now I get:
> git push origin memory_grassrc_setting
> To github.com:neteler/grass.git
>  ! [rejected]            memory_grassrc_setting ->
> memory_grassrc_setting (non-fast-forward)
> error: failed to push some refs to 'git at github.com:neteler/grass.git'
> hint: Updates were rejected because the tip of your current branch is behind
> hint: its remote counterpart. Integrate the remote changes (e.g.
> hint: 'git pull ...') before pushing again.
> hint: See the 'Note about fast-forwards' in 'git push --help' for details.
> What happened, if I recall correctly, is that I edited one thing via
> GitHub web interface.
> This will be missing from my local repo and hence the push command
> throws an error.
Cool, Vero told me the trick (thanks!):
git pull origin memory_grassrc_settings
(here I got an expected conflict which I fixed and committed)
then:
and all successfully updated in PR922.
Markus
