[GRASS-dev] GUI -> change working directory - what should this action do?
Vaclav Petras
wenzeslaus at gmail.com
Sun Dec 13 20:10:58 PST 2020
On Fri, Dec 11, 2020 at 5:32 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> today, I saw for the first time ;-) in the GUI:
...and there might be more :-)
> Settings → GRASS working environment → Change working directory.
Call os.chdir(), Python equivalent of unix cd, i.e., change current working
directory. Is this something outlandish on Windows? Try also cd command in
Console.
> has this ever be tested in winGRASS?
Tested and used at least in classrooms.
> how could this be tested?
Any module with import, export, read, or save file will use the current
working directory when a filename, but no (or relative) path is specified.
Vaclav
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20201213/0167fc57/attachment.html>
