[GRASS-dev] GUI -> change working directory - what should this action do?
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Dec 14 01:08:28 PST 2020
On Mon, Dec 14, 2020 at 5:11 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Dec 11, 2020 at 5:32 PM Helmut Kudrnovsky <hellik at web.de> wrote:
>> hi,
>> today, I saw for the first time ;-) in the GUI:
> ...and there might be more :-)
>> Settings → GRASS working environment → Change working directory.
> Call os.chdir(), Python equivalent of unix cd, i.e., change current
> working directory. Is this something outlandish on Windows? Try also cd
> command in Console.
I hadn't seen that either, thanks for pointing this out, and a very handy
feature indeed!
>> has this ever be tested in winGRASS?
> Tested and used at least in classrooms.
>> how could this be tested?
> Any module with import, export, read, or save file will use the current
> working directory when a filename, but no (or relative) path is specified.
> Vaclav
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20201214/2cc2bf75/attachment.html>
