[GRASS-dev] [GRASS GIS] #2499: v.in.ogr in does not handle "nan" in attribute tables properly
trac at osgeo.org
Tue Jan 7 01:51:23 PST 2020
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.3
Component: Vector | Version: unspecified
Resolution: | Keywords: v.in.ogr, DBMI, SQLite, nan
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:11 sbl]:
> Here is how it was handeled in Pandas:
> https://github.com/pandas-dev/pandas/pull/8208
> As a simple example for reproduction (though not with v.net.centrality)
you could do:
> db.execute sql="CREATE TABLE test (column double precision);"
> db.execute sql="INSERT INTO test VALUES (-nan);"
> # in contrast to
> db.execute sql="INSERT INTO test VALUES (NULL);"
> SQLite seems to have a workaround:
http://system.data.sqlite.org/index.html/tktview/e06c4caff3c433c80616ae5c6df63fc830825e59
> But that does not seem to be available in default packages of SQLite and
other DBMIs seem to struggle With nan/NaN as well… So, this does not seem
to be trivial...
The SQLite workaround with !GetAllAsText seems ugly. What works is
db.execute sql="INSERT INTO test VALUES ('-nan');"
but then SQLite converts '-nan' to -0 (zero) which is wrong. Same for
inf/-inf. Using NULL is also not correct, because NULL means "no entry",
whereas nan and inf are numbers that can be represented as floating point
numbers.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2499#comment:12>
