[GRASS-dev] [GRASS GIS] #2499: v.in.ogr in does not handle "nan" in attribute tables properly
trac at osgeo.org
Wed Jan 8 06:25:27 PST 2020
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.3
Component: Vector | Version: unspecified
Resolution: | Keywords: v.in.ogr, DBMI, SQLite, nan
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
In addition, the different DMBS behave differently with regards to
nan/inf...
This is how PostgreSQL handles NaN / Inf in double columns:
CREATE TEMPORARY TABLE test_insert_nan (double_column double precision);
INSERT INTO test_insert_nan VALUES ('nan');
INSERT INTO test_insert_nan VALUES ('-nan');
INSERT INTO test_insert_nan VALUES ('inf');
INSERT INTO test_insert_nan VALUES ('-inf');
SELECT * FROM test_insert_nan;
double_column
double precision
"NaN"
"NaN"
"Infinity"
"-Infinity"
SELECT * FROM test_insert_nan WHERE double_column > 0;
double_column
double precision
"NaN"
"NaN"
"Infinity"
SELECT * FROM test_insert_nan WHERE double_column < 0;
double_column
double precision
"-Infinity"
However, in PostgreSQL does not insert nan / inf strings columns of type
numeric...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2499#comment:13>
