[GRASS-dev] [GRASS GIS] #3880: update/drop revision check after git switch
trac at osgeo.org
Fri Jan 10 09:14:32 PST 2020
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.8.3
Component: Compiling | Version: svn-releasebranch76
Resolution: | Keywords: svn, git, revision
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:6 neteler]:
> Note: it lead to https://github.com/OSGeo/grass/pull/278
The patch in PR278 for gisinit.c is masking a more serious problem with
ctypes generated for Python 3.8: the string "$Revision$" is truncated to
its first character "$", then "$" is compared to "$Revision$" which fails
of course. Such truncations of strings to their first character must occur
elsewhere too, which will only become apparent at a later stage when
executing a Python module that uses ctypes, probably causing fairly
cryptic errors.
The test in gisinit.c as it is now always compares "$Revision$" to
"$Revision$" (in GRASS C modules) which always succeeds which is bad. We
could instead use GRASS_VERSION_STRING from include/version.h to catch the
obvious cases: module x as been compiled against GRASS 7.y and is
attempted to be used with GRASS 7.z.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3880#comment:7>
