[GRASS-dev] [GRASS GIS] #3880: update/drop revision check after git switch
GRASS GIS trac at osgeo.org
Fri Jan 10 09:22:39 PST 2020
  Reporter:  hellik     |      Owner:  grass-dev@…
      Type:  defect     |     Status:  reopened
  Priority:  blocker    |  Milestone:  7.8.3
 Component:  Compiling  |    Version:  svn-releasebranch76
Resolution:             |   Keywords:  svn, git, revision
       CPU:  All        |   Platform:  All
Comment (by neteler):
 Replying to [comment:7 mmetz]:
 > We could instead use GRASS_VERSION_STRING from include/version.h to
 catch the obvious cases: module x as been compiled against GRASS 7.y and
 is attempted to be used with GRASS 7.z.
 This sounds good to me.
 (of course the "docker/alpine/alpine-py38-gisinit.patch" in
 https://github.com/OSGeo/grass/pull/278 can then be removed)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3880#comment:8>
