[GRASS-dev] [GRASS GIS] #3880: update/drop revision check after git switch
trac at osgeo.org
Fri Jan 10 12:55:05 PST 2020
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.8.3
Component: Compiling | Version: svn-releasebranch76
Resolution: | Keywords: svn, git, revision
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:8 neteler]:
> Replying to [comment:7 mmetz]:
> > We could instead use GRASS_VERSION_STRING from include/version.h to
catch the obvious cases: module x as been compiled against GRASS 7.y and
is attempted to be used with GRASS 7.z.
> This sounds good to me.
OK
> (of course the "docker/alpine/alpine-py38-gisinit.patch" in
https://github.com/OSGeo/grass/pull/278 can then be removed)
This patch does not solve problems, it masks problems because no errors
occur in GRASS core, only when compiling certain addons.
The patch in PR278 for gisinit.c is masking a more serious problem with
ctypes generated for Python 3.8: the string "$Revision$" is truncated to
its first character "$", then "$" is compared to "$Revision$" which fails
of course. Such truncations of strings to their first character must occur
elsewhere too, which will only become apparent at a later stage when
executing a Python module that uses ctypes, probably causing fairly
cryptic errors.
Which parts of this description need to be elaborated?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3880#comment:9>
