[GRASS-dev] [GRASS GIS] #3880: update/drop revision check after git switch
trac at osgeo.org
Fri Jan 10 13:01:33 PST 2020
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.8.3
Component: Compiling | Version: svn-releasebranch76
Resolution: | Keywords: svn, git, revision
CPU: All | Platform: All
Comment (by neteler):
Replying to [comment:9 mmetz]:
> The patch in PR278 for gisinit.c is masking a more serious problem with
ctypes
Keep in mind that this temporary patch is only in the Alpine build.
> Which parts of this description need to be elaborated?
All fine - the question (for me) is only how to change the gisinit.c code
to use GRASS_VERSION_STRING.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3880#comment:10>
