[GRASS-dev] silly question
Michael Barton
Michael.Barton at asu.edu
Wed Mar 4 16:11:36 PST 2020
Thanks Luca,
I also found someone here that pointed that out. I originally got instructions from the GRASS WIKI. There is either an error or it is something that does not work for Macs. The examples use a colon to indicate the repository owner instead of a slash. I had fixed that for the original clone command but did not catch it for the one setting upstream.
Also learned a new one that is exactly what I need in some circumstances:
git reset --hard origin/master
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc
On Mar 4, 2020, at 3:30 PM, Luca Delucchi <lucadeluge at gmail.com<mailto:lucadeluge at gmail.com>> wrote:
Hi Michael,
On Wed, 4 Mar 2020 at 19:49, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I want to do something that should be simple but it is not. I want to be able to update my fork of GRASS source code from master. The wiki instructions say I should be able to do this with:
git fetch upstream
git rebase upstream/master
But when I do, I get:
unable to access 'https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e= ': Port number ended with 'O<https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=%20':%20Port%20number%20ended%20with%20'O>'
it seems wrong the url, it should be https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_grass.git&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=2s0FIt9ZZMaEF8dGFczUzV71CeMzJZ3MBNeNaOmhcp4&e=
Any suggestions? I don't want to have to keep forking and cloning
Michael
ciao
Luca
www.lucadelu.org<http://www.lucadelu.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/82a76299/attachment.html>
