[GRASS-dev] silly question
Anna Petrášová
kratochanna at gmail.com
Wed Mar 4 17:09:19 PST 2020
Perhaps caused by some mixing of cloning with HTTPS vs SSH?
git clone git at github.com:petrasovaa/grass.git
git clone https://github.com/petrasovaa/grass.git
The instructions assume ssh.
On Wed, Mar 4, 2020 at 7:11 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> Thanks Luca,
> I also found someone here that pointed that out. I originally got
> instructions from the GRASS WIKI. There is either an error or it is
> something that does not work for Macs. The examples use a colon to indicate
> the repository owner instead of a slash. I had fixed that for the original
> clone command but did not catch it for the one setting upstream.
> Also learned a new one that is exactly what I need in some circumstances:
> git reset --hard origin/master
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, https://complexity.asu.edu/csdc
> On Mar 4, 2020, at 3:30 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi Michael,
> On Wed, 4 Mar 2020 at 19:49, Michael Barton <Michael.Barton at asu.edu>
> wrote:
> I want to do something that should be simple but it is not. I want to be
> able to update my fork of GRASS source code from master. The wiki
> instructions say I should be able to do this with:
> git fetch upstream
> git rebase upstream/master
> But when I do, I get:
> unable to access 'https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=
> ': Port number ended with 'O
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com-3AOSGeo_grass.git_&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=t9pyApmJY3B5H0nFh-Gm1IG1VGltt378-0JryEOEZG8&e=%20':%20Port%20number%20ended%20with%20'O>
> it seems wrong the url, it should be
> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_OSGeo_grass.git&d=DwIBaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=ocylBhKg4eZ-QJLCBa53vt3dUwHB_ZET96-XkejX2FU&s=2s0FIt9ZZMaEF8dGFczUzV71CeMzJZ3MBNeNaOmhcp4&e=
> Any suggestions? I don't want to have to keep forking and cloning
> Michael
> ciao
> Luca
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200304/023edce7/attachment-0001.html>
