[GRASS-dev] Automatic/CI compilation on macOS
Rainer M Krug
Rainer at krugs.de
Thu Mar 5 01:27:25 PST 2020
OK - found the ci.
The formula installs, but I get a warning at the end, which results in a warning, which is than interpreted as an error. The warning (which I also get locally) is the following:
If it is the case that you can change the shebang at the beginning of
he script to enforce Python 3 usage.
#!/usr/bin/env python
Should be changed into
#!/usr/bin/env python3
I suspect that this needs to be done in GRASS itself?
Rainer
> On 5 Mar 2020, at 09:40, Rainer Krug <rainer_krug at icloud.com> wrote:
> Sorry for chiming in so late - haven’t followed GRASS closely and I might raise points which have already been discussed.
> I can not comment on conda, as I never used it.
> I made a fix on the home-brew-osgeo4mac branch as the test using for the brew test needs the name of the formula. I tried the installation and the brew test locally, and it works.
> Where can I see the log from the ci?
> There were also discussions on the R mailing list to support Conda, and it definitely has its user base, but O don’t think it is as widely used as home-brew. So supporting both would be the best option.
> Especially, if I am not mistaken, the support for the osgeo4mac-grass formula for home-brew is already taken care of by osgeo4mac.
> Cheers,
> Rainer
>> On 5 Mar 2020, at 04:58, Vaclav Petras <wenzeslaus at gmail.com <mailto:wenzeslaus at gmail.com>> wrote:
>> Dear all,
>> I made some updates towards updating the conda recipe for GRASS GIS on macOS by Eric Hutton, but it is not working yet. You can find the WIP PR here:
>> https://github.com/csdms-stack/grass-recipe/pull/1 <https://github.com/csdms-stack/grass-recipe/pull/1>
>> You can see the current state in Travis linked from the PR or in GitHub Actions of my fork:
>> https://github.com/wenzeslaus/grass-recipe/tree/updates-for-7.8-and-above <https://github.com/wenzeslaus/grass-recipe/tree/updates-for-7.8-and-above>
>> https://github.com/wenzeslaus/grass-recipe/actions <https://github.com/wenzeslaus/grass-recipe/actions>
>> If you think a different approach is more appropriate and want to try it out, you can consider contributing to the following repository which now, for example, contains a homebrew-osgeo4mac based branch. Again see the current state in GitHub Actions:
>> https://github.com/GRASS-GIS/grass-gis-experimental-ci/tree/homebrew-osgeo4mac <https://github.com/GRASS-GIS/grass-gis-experimental-ci/tree/homebrew-osgeo4mac>
>> If you have some ideas for fixing the errors, please let me know, here, by PRs, issues, or links to other repos.
>> Thanks,
>> Vaclav
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
> Orcid ID: 0000-0002-7490-0066
> Department of Evolutionary Biology and Environmental Studies
> University of Zürich
> Office Y34-J-74
> Winterthurerstrasse 190
> 8075 Zürich
> Switzerland
> Office: +41 (0)44 635 47 64
> Cell: +41 (0)78 630 66 57
> email: Rainer.Krug at uzh.ch <mailto:Rainer.Krug at uzh.ch>
> Rainer at krugs.de <mailto:Rainer at krugs.de>
> Skype: RMkrug
> PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/7d8496ad/attachment.html>
