[GRASS-dev] Automatic/CI compilation on macOS
Vaclav Petras
wenzeslaus at gmail.com
Thu Mar 5 08:53:04 PST 2020
On Thu, Mar 5, 2020 at 11:37 AM Rainer M Krug <Rainer at krugs.de> wrote:
> OK - one step closer to success. Now I just have to know the location
> where the data for the tests can be downloaded from (I guess).
Everything is in the repo, well, it needs to be, I guess the only question
is where in the repo, so:
https://github.com/GRASS-GIS/grass-gis-experimental-ci/blob/homebrew-osgeo4mac/test_thorough.sh
> Please check the log to at
> https://github.com/GRASS-GIS/grass-gis-experimental-ci/runs/487969965?check_suite_focus=true for
> the *Basic test* and the *Thorough test*. I will look at the return code
> later, when the tests are running.
The problem there is probably a bad/missing path to PROJ db. I think it
complains during the configuration already, so perhaps correct
--with-proj-share will fix it. The runtime way of setting it is PROJ_LIB
environmental variable. You can try something along these lines.
> Rainer
> On 5 Mar 2020, at 16:28, Rainer M Krug <Rainer at krugs.de> wrote:
> On 5 Mar 2020, at 16:22, Rainer M Krug <Rainer at krugs.de> wrote:
> On 5 Mar 2020, at 14:52, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Mar 5, 2020 at 4:27 AM Rainer M Krug <Rainer at krugs.de> wrote:
>> OK - found the ci.
>> The formula installs, but I get a warning at the end, which results in a
>> warning, which is than interpreted as an error. The warning (which I also
>> get locally) is the following:
>> If it is the case that you can change the shebang at the beginning of
>> he script to enforce Python 3 usage.
>> #!/usr/bin/env python
>> Should be changed into
>> #!/usr/bin/env python3
>> I suspect that this needs to be done in GRASS itself?
> Hi, thanks for looking into this. 7.8.2 (and also above) has python3
> everywhere in shebang. See e.g.:
> $ grep -Irn "/usr/bin/env python[^3]"
> scripts/g.extension/g.extension.py:1059:
> "#!/usr/bin/env python\n",
> scripts/g.extension/g.extension.py:1308:
> # (these two are in fact code which is doing the replacement to python3)
> Can you please investigate locally where the message coming from?
> The message comes from the formula as a Caveat. I *think* it is always
> displayed. But at the moment, I am not to sure where the error code comes
> from, as I get an error code at the end of the brew command of 0 locally.
> I will look into this.
> Please ignore the following about the checkout.
> Found it.
> Do you know, why there is a
> - uses: actions/checkout at v2
> In the action?
> It seems, that it will be executed last, and there is no checkout needed.
> Rainer
> Vaclav
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
> (Conservation Biology, UCT), Dipl. Phys. (Germany)
> Orcid ID: 0000-0002-7490-0066
> Department of Evolutionary Biology and Environmental Studies
> University of Zürich
> Office Y34-J-74
> Winterthurerstrasse 190
> 8075 Zürich
> Switzerland
> Office: +41 (0)44 635 47 64
> Cell: +41 (0)78 630 66 57
> email: Rainer.Krug at uzh.ch <Rainer.Krug at uzh.ch>
> Rainer at krugs.de
> Skype: RMkrug
> PGP: 0x0F52F982
> Office Y34-J-74
> 8075 Zürich
> Switzerland
> Rainer at krugs.de
> Skype: RMkrug
> PGP: 0x0F52F982
> Office Y34-J-74
> 8075 Zürich
> Switzerland
> Rainer at krugs.de
> Skype: RMkrug
> PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/acf84937/attachment-0001.html>
