[GRASS-dev] Automatic/CI compilation on macOS
Rainer M Krug
Rainer at krugs.de
Thu Mar 5 08:13:52 PST 2020
OK - one step closer to success. Now I just have to know the location where the data for the tests can be downloaded from (I guess). Please check the log to at https://github.com/GRASS-GIS/grass-gis-experimental-ci/runs/487969965?check_suite_focus=true <https://github.com/GRASS-GIS/grass-gis-experimental-ci/runs/487969965?check_suite_focus=true> for the Basic test and the Thorough test. I will look at the return code later, when the tests are running.
Rainer
> On 5 Mar 2020, at 16:28, Rainer M Krug <Rainer at krugs.de> wrote:
>> On 5 Mar 2020, at 16:22, Rainer M Krug <Rainer at krugs.de <mailto:Rainer at krugs.de>> wrote:
>>> On 5 Mar 2020, at 14:52, Vaclav Petras <wenzeslaus at gmail.com <mailto:wenzeslaus at gmail.com>> wrote:
>>> On Thu, Mar 5, 2020 at 4:27 AM Rainer M Krug <Rainer at krugs.de <mailto:Rainer at krugs.de>> wrote:
>>> OK - found the ci.
>>> The formula installs, but I get a warning at the end, which results in a warning, which is than interpreted as an error. The warning (which I also get locally) is the following:
>>> If it is the case that you can change the shebang at the beginning of
>>> he script to enforce Python 3 usage.
>>> #!/usr/bin/env python
>>> Should be changed into
>>> #!/usr/bin/env python3
>>> I suspect that this needs to be done in GRASS itself?
>>> Hi, thanks for looking into this. 7.8.2 (and also above) has python3 everywhere in shebang. See e.g.:
>>> $ grep -Irn "/usr/bin/env python[^3]"
>>> scripts/g.extension/g.extension.py:1059 <http://g.extension.py:1059/>: "#!/usr/bin/env python\n",
>>> scripts/g.extension/g.extension.py:1308 <http://g.extension.py:1308/>: "#!/usr/bin/env python\n",
>>> # (these two are in fact code which is doing the replacement to python3)
>>> Can you please investigate locally where the message coming from?
>> The message comes from the formula as a Caveat. I *think* it is always displayed. But at the moment, I am not to sure where the error code comes from, as I get an error code at the end of the brew command of 0 locally.
>> I will look into this.
> Please ignore the following about the checkout.
> Found it.
>> Do you know, why there is a
>> - uses: actions/checkout at v2
>> In the action?
>> It seems, that it will be executed last, and there is no checkout needed.
>> Rainer
>>> Vaclav
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Orcid ID: 0000-0002-7490-0066
>> Department of Evolutionary Biology and Environmental Studies
>> University of Zürich
>> Office Y34-J-74
>> Winterthurerstrasse 190
>> 8075 Zürich
>> Switzerland
>> Office: +41 (0)44 635 47 64
>> Cell: +41 (0)78 630 66 57
>> email: Rainer.Krug at uzh.ch <mailto:Rainer.Krug at uzh.ch>
>> Skype: RMkrug
>> PGP: 0x0F52F982
> Office Y34-J-74
> 8075 Zürich
> Switzerland
> Skype: RMkrug
> PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/adc71374/attachment.html>
