[GRASS-dev] Automatic/CI compilation on macOS
Rainer M Krug Rainer at krugs.de
Thu Mar 5 07:28:36 PST 2020
> On 5 Mar 2020, at 16:22, Rainer M Krug <Rainer at krugs.de> wrote:
>> On 5 Mar 2020, at 14:52, Vaclav Petras <wenzeslaus at gmail.com <mailto:wenzeslaus at gmail.com>> wrote:
>> On Thu, Mar 5, 2020 at 4:27 AM Rainer M Krug <Rainer at krugs.de <mailto:Rainer at krugs.de>> wrote:
>> OK - found the ci.
>> The formula installs, but I get a warning at the end, which results in a warning, which is than interpreted as an error. The warning (which I also get locally) is the following:
>> If it is the case that you can change the shebang at the beginning of
>> he script to enforce Python 3 usage.
>>   #!/usr/bin/env python
>> Should be changed into
>>   #!/usr/bin/env python3
>> I suspect that this needs to be done in GRASS itself?
>> Hi, thanks for looking into this. 7.8.2 (and also above) has python3 everywhere in shebang. See e.g.:
>> $ grep -Irn "/usr/bin/env python[^3]"
>> scripts/g.extension/g.extension.py:1059 <http://g.extension.py:1059/>:                    "#!/usr/bin/env python\n",
>> scripts/g.extension/g.extension.py:1308 <http://g.extension.py:1308/>:                    "#!/usr/bin/env python\n",
>> # (these two are in fact code which is doing the replacement to python3)
>> Can you please investigate locally where the message coming from?
> The message comes from the formula as a Caveat. I *think* it is always displayed. But at the moment, I am not to sure where the error code comes from, as I get an error code at the end of the brew command of 0 locally.
> I will look into this.
Please ignore the following about the checkout.
Found it.
> Do you know, why there is a
> 	- uses: actions/checkout at v2
> In the action?
> It seems, that it will be executed last, and there is no checkout needed.
> Rainer
>> Vaclav
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
> Orcid ID: 0000-0002-7490-0066
> Department of Evolutionary Biology and Environmental Studies
> University of Zürich
> Office Y34-J-74
> Winterthurerstrasse 190
> 8075 Zürich
> Switzerland
> Office:	+41 (0)44 635 47 64
> Cell:       	+41 (0)78 630 66 57
> email:      Rainer.Krug at uzh.ch <mailto:Rainer.Krug at uzh.ch>
> Skype:     RMkrug
> PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
		Rainer at krugs.de
Skype:     RMkrug
PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200305/962aee5e/attachment-0001.html>
