[GRASS-dev] db.copy gives error
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Mar 24 01:38:18 PDT 2020
On Sat, Mar 14, 2020 at 11:39 PM Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Sat, Mar 14, 2020 at 3:27 PM Paulo van Breugel <p.vanbreugel at gmail.com> wrote:
> > Dear devs,
> > I have a grassgis database with in the mapset 'Permanent' a table
> > 'vegetation_lookup'. I want top copy this table to the current mapset.
> > The following used to work I think, but now gives me some errors:
> > db.copy from_driver=sqlite
> > from_database=/media/grassdb/biodiv/PERMANENT/sqlite/sqlite.db
> > from_table=vegetation_lookup to_driver=sqlite
> > to_database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> > to_table=vegetation_lookup
> Looking at the code of db.copy, it is not possible that this ever worked, you need to replace the variables with their actual values.
Yes, I did work with the actual values, which gave me the error below.
Then I tried the above, but that as you rightly noted, shouldn't, and
didn't work either. In the meantime I recreated the database and did a
fresh install of grass, and now my script works again. I am not sure
which of the two made it work again (should have done this more
systematically), but in any case, thanks for the feedback Markus.
> Markus M
> > ERROR: Unable to create directory '///sqlite' for sqlite database
> > dbmi: Protocol error
> > WARNING: Unable to open database <///sqlite/sqlite.db> by driver <sqlite>
> > Any idea what I am doing wrong here?
> > With kind regards,
> > Paulo
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
