[GRASS-dev] db.copy gives error
Moritz Lennert
mlennert at club.worldonline.be
Tue Mar 24 02:18:21 PDT 2020
Am 14. März 2020 23:38:58 MEZ schrieb Markus Metz <markus.metz.giswork at gmail.com>:
>On Sat, Mar 14, 2020 at 3:27 PM Paulo van Breugel
><p.vanbreugel at gmail.com>
>wrote:
>> Dear devs,
>> I have a grassgis database with in the mapset 'Permanent' a table
>> 'vegetation_lookup'. I want top copy this table to the current
>mapset.
>> The following used to work I think, but now gives me some errors:
>> db.copy from_driver=sqlite
>> from_database=/media/grassdb/biodiv/PERMANENT/sqlite/sqlite.db
>> from_table=vegetation_lookup to_driver=sqlite
>> to_database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>> to_table=vegetation_lookup
>Looking at the code of db.copy, it is not possible that this ever
>worked,
>you need to replace the variables with their actual values.
Well, it should work if you run
eval $(g.gisenv -s) before, no ?
Moritz
