[GRASS-dev] grass on osgeo4w and spyder
Helmut Kudrnovsky
hellik at web.de
Tue Mar 24 13:31:12 PDT 2020
pvanbosgeo wrote
> Hi devs,
> Has any of you experience in running Spyder (or any other Python IDE)
> from the GRASS command line (GRASS installed on Windows 10 with
> OSGeo4W)? Any tips for how to set this up?
> I can run R/Rstudio from the GRASS command line. Nothing to set up,
> just typing in rstudio on the grass gis command line to fire up
> rstudio.
> That does not work, however, with Spyder (installed with Anaconda). As
> an alternative, I tried to install Spyder with pip on the osgeo4w
> command line. Installation seems to work, but when typing in spyder3
> on the command line, nothing happens.
have a look at
https://grasswiki.osgeo.org/wiki/Tools_for_Python_programming#PyCharm_IDE
it's related to
add python-grass.bat for Python initialization
https://github.com/OSGeo/grass/pull/436
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
