[GRASS-dev] Busy SQLITE db
Luca Delucchi
lucadeluge at gmail.com
Mon May 4 01:47:11 PDT 2020
Hi all,
I'm facing the problem with Busy SQLITE db using GRASS 7.8 in a HPC system.
Reading other problems like that I saw a Metz answer [0] and another
from Luis [1] but I'm not able to fix the problem. Now the mapset is
unusable with vector.
Do you have any idea how to solve the problem and where it come from?
g.remove type=vector name=nuts2_lst_2003_daily -f
Removing vector <nuts2_lst_2003_daily>
WARNING: Busy SQLITE db, already waiting for 10 seconds...
WARNING: Busy SQLITE db, already waiting for 20 seconds...
[0] http://osgeo-org.1560.x6.nabble.com/SQLITE-db-locking-problem-td5182180.html
[1] https://gis.stackexchange.com/questions/321986/grass-what-to-do-when-the-sqlite-database-becomes-busy
ciao
Luca
www.lucadelu.org
