[GRASS-dev] Busy SQLITE db
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Mon May 4 02:18:07 PDT 2020
Ciao Luca,
If you have stale processes e.g. on cluster nodes that have the DB opened this may occur.
Also the file system can have an impact (e.g. writing to an SQLite DB on a CIFS file system from Linux is simply impossible). But that should give a different error message.
So I would look for hanging processes... And you could try to copy the mapset, remove the old one and rename the copy back...
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Luca Delucchi
Sent: mandag 4. mai 2020 10:47
To: GRASS-dev <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] Busy SQLITE db
Hi all,
I'm facing the problem with Busy SQLITE db using GRASS 7.8 in a HPC system.
Reading other problems like that I saw a Metz answer [0] and another from Luis [1] but I'm not able to fix the problem. Now the mapset is unusable with vector.
Do you have any idea how to solve the problem and where it come from?
g.remove type=vector name=nuts2_lst_2003_daily -f Removing vector <nuts2_lst_2003_daily>
WARNING: Busy SQLITE db, already waiting for 10 seconds...
WARNING: Busy SQLITE db, already waiting for 20 seconds...
[0] http://osgeo-org.1560.x6.nabble.com/SQLITE-db-locking-problem-td5182180.html
[1] https://gis.stackexchange.com/questions/321986/grass-what-to-do-when-the-sqlite-database-becomes-busy
ciao
Luca
www.lucadelu.org
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
