[GRASS-dev] Busy SQLITE db
Luca Delucchi
lucadeluge at gmail.com
Wed May 6 14:23:01 PDT 2020
On Mon, 4 May 2020 at 11:18, Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Ciao Luca,
Ciao Stefan,
> If you have stale processes e.g. on cluster nodes that have the DB opened this may occur.
first time it happen---
> Also the file system can have an impact (e.g. writing to an SQLite DB on a CIFS file system from Linux is simply impossible). But that should give a different error message.
> So I would look for hanging processes... And you could try to copy the mapset, remove the old one and rename the copy back...
yes, I would avoid this, but it worked
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
