[GRASS-dev] Busy SQLITE db
Markus Neteler
neteler at osgeo.org
Wed May 6 15:14:40 PDT 2020
Hi Luca,
On Mon, May 4, 2020 at 10:47 AM Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi all,
> I'm facing the problem with Busy SQLITE db using GRASS 7.8 in a HPC system.
Which file system do you use?
> Reading other problems like that I saw a Metz answer [0] and another
> from Luis [1] but I'm not able to fix the problem. Now the mapset is
> unusable with vector.
> Do you have any idea how to solve the problem and where it come from?
> g.remove type=vector name=nuts2_lst_2003_daily -f
> Removing vector <nuts2_lst_2003_daily>
> WARNING: Busy SQLITE db, already waiting for 10 seconds...
> WARNING: Busy SQLITE db, already waiting for 20 seconds...
Do you use NFS by chance?
ciao,
markusN
> [0] http://osgeo-org.1560.x6.nabble.com/SQLITE-db-locking-problem-td5182180.html
> [1] https://gis.stackexchange.com/questions/321986/grass-what-to-do-when-the-sqlite-database-becomes-busy
> ciao
> Luca
> www.lucadelu.org
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
