[GRASS-dev] Fwd: [mlennert/grass] Run failed: CI - master (6669a4d)
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri May 8 04:44:04 PDT 2020
Hi Moritz,
This is a known issue with tests on Ubuntu 16.04.
See Vaclavs explanation here:
https://github.com/OSGeo/grass/pull/583#issuecomment-625402357
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Moritz Lennert
Sent: fredag 8. mai 2020 13:00
To: grass-dev <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] Fwd: [mlennert/grass] Run failed: CI - master (6669a4d)
Am I right in my interpretation that below build failures are not linked to my PR ? IIUC, the errors are in Python scripts and linked to the
flake8 changes ?
Moritz
-------- Forwarded Message --------
Subject: [mlennert/grass] Run failed: CI - master (6669a4d)
Date: Fri, 08 May 2020 10:07:33 +0000 (UTC)
Reply-To: mlennert/grass <noreply at github.com>
To: mlennert/grass <grass at noreply.github.com>
CC: Ci activity <ci_activity at noreply.github.com>
Run failed for master (6669a4d)
Repository: mlennert/grass
Workflow: CI
Duration: 46 minutes and 13.0 seconds
Finished: 2020-05-08 10:07:17 UTC
View results <https://github.com/mlennert/grass/actions/runs/99001844>
Jobs:
* ubuntu-16.04 tests
<https://github.com/mlennert/grass/runs/655886759> failed (1
annotation)
* ubuntu-18.04 tests
<https://github.com/mlennert/grass/runs/655886766> succeeded (0
annotations)
* ubuntu-16.04 build
<https://github.com/mlennert/grass/runs/655886796> failed (1
annotation)
* ubuntu-18.04 build
<https://github.com/mlennert/grass/runs/655886805> succeeded (0
annotations)
You are receiving this because this workflow ran on your branch.
Manage your GitHub Actions notifications here
<https://github.com/settings/notifications>.
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
