[GRASS-dev] Unable to install grass-core on debian 10 (buster)
aborruso
aborruso at gmail.com
Mon May 18 07:46:43 PDT 2020
There is something very strange: it's already installed. If I run "apt policy
grass-core" I have the text below.
I don't understand why it doesn't warn me when I try to install it. Sorry
for the confusion and thank you very much for your time, I solved it
grass-core:
Installed: 7.8.0-1
Candidate: 7.8.3-1
Version table:
7.8.3-1 990
990 https://deb.debian.org/debian testing/main amd64 Packages
500 https://deb.debian.org/debian unstable/main amd64 Packages
*** 7.8.0-1 100
100 /var/lib/dpkg/status
7.6.0-1 500
500 https://deb.debian.org/debian stable/main amd64 Packages
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
