[GRASS-dev] Unable to install grass-core on debian 10 (buster)
Sebastiaan Couwenberg sebastic at xs4all.nl
Mon May 18 07:51:41 PDT 2020
On 5/18/20 4:46 PM, aborruso wrote:
> grass-core:
>   Installed: 7.8.0-1
>   Candidate: 7.8.3-1
>   Version table:
>      7.8.3-1 990
>         990 https://deb.debian.org/debian testing/main amd64 Packages
>         500 https://deb.debian.org/debian unstable/main amd64 Packages
>  *** 7.8.0-1 100
>         100 /var/lib/dpkg/status
>      7.6.0-1 500
>         500 https://deb.debian.org/debian stable/main amd64 Packages
Don't add testing/unstable sources to an stable system.
If you need newer packages than available in stable and its backports,
upgrade to testing following the usual distribution upgrade procedure.
Alternatively create your own backports of the newer packages you need.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
