[GRASS-dev] PROJ version in WinGRASS
Roger Bivand
Roger.Bivand at nhh.no
Sun Apr 11 07:59:16 PDT 2021
In: https://lists.osgeo.org/pipermail/grass-stats/2021-April/001834.html
I draw attention to an issue raised with regard to the version of PROJ
proj.db bundled with WinGRASS. Across the EPSG 9/10 border, table and
field names change, so PROJ itself builds differently, and g.proj is built
to handle the proj.db/EPSG version it "sees". If PROJ_LIB is changed to a
different proj.db/EPSG version, obviously problems occur.
Is there a way to declare the EPSG version in g.proj, preferably before
7.8.6 ships? For now the work-around in rgrass7 is to trap the error found
when g.proj expects EPSG 9 and is pointed at 10, and fall back from WKT2
to Proj4 string representation.
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
