[GRASS-dev] [release planning] GRASS GIS 8: create new release branch
Vaclav Petras
wenzeslaus at gmail.com
Thu Aug 5 19:28:38 PDT 2021
Are we ready to create the 8.0 release branch?
Once we create it, we will need to backport (cherry-pick) updates from the
master branch when needed.
Please see the following for the individual issues we still have and post
here if you see some priorities.
On Wed, Jul 14, 2021 at 5:24 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Windows build & test is just bad (no bug or PR so far?),
> Can someone give an update on that, please?
> #1683 is not merged yet, but missing sh in the test environment is not a
> blocker in this case.
https://github.com/OSGeo/grass/pull/1683
Tests are running!
> CentOS is too
>> old (#1709) & needs auto tools update to fix it (or at least env
>> variable in build script as I just have done to enable testing in
>> #1501),
> ...or CentOS 8, CentOS Stream, or remove the CentOS test.
> https://github.com/OSGeo/grass/issues/1709#issuecomment-880215427
It would be better if Autotools are updated, but CentOS build works now.
Are there any pressing issues?
>> I would also strongly advocate merging ctypes upgrade before 8.0
> Seems to be close to being finished too.
ctypes update is closer everyday, but not finished yet. Maybe not needed
for 8.0?
https://github.com/OSGeo/grass/pull/1651
On Wed, Jul 28, 2021 at 4:28 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> 2021-07-27 18:26 GMT+03:00, Vaclav Petras <wenzeslaus at gmail.com>:
> > From what has the milestone 8.0 and is not mentioned below and is major,
> I
> > see only #1454 and #1501 which are related to band references. Maybe we
> > should again consider reverting the band references in order to get 8.0
> out
> > or how do you see the status of #1454 and #1501, Martin and Maris?
> > https://github.com/OSGeo/grass/milestone/4
> > https://github.com/OSGeo/grass/pull/1454
> > https://github.com/OSGeo/grass/pull/1501
> For #1454 the main remaining (and unsolvable) issue is semantics of a
> mapset layout and its management functions. I just commited a more
> clean workaround and thus it should be ready for a merge. A proper
> solution will have to wait for GRASS 9 when we could reorganize mapset
> structure and thus also clean-up naming, handling functions etc.
#1501 (Integrate band references into portable signature files) is close to
being merged.
#1454 (TGIS DB v3 backward compatible with v2) has perhaps lower priority
since there is both upgrade and downgrade.
As for issues linked to the milestone, please review what is there. See
what needs to stay there and what can be moved. For example, all issues
which are features and are not changing existing API can be moved to 8.2
milestone.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210805/c3f7bd4e/attachment.html>
