[GRASS-dev] GRASS 7.8.5 compile errors
Maris Nartiss maris.gis at gmail.com
Thu Aug 12 09:39:30 PDT 2021
Hello Thomas,
I gave you a wrong path. Try this one:
ldd /home/teaiii/grass-7.8.5/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.so
The problem still boils down to having different incompatible system
libraries during compilation and runtime. You can also search for
libproj.so files in /usr/lib(64) or just dpkg -l | grep proj and if
you see multiple proj versions, remove one.
Māris.
2021-08-12 13:11 GMT+03:00, Thomas Adams <tea3rd at gmail.com>:
> Hi Māris,
> When I run the command ldd /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so |
> grep proj , I get:
> ldd: /home/teaiii/grass-7.8.5/lib/libgrass_gproj.so: No such file or
> directory
> There is no libgrass_gproj.so file in /home/teaiii/grass-7.8.5/lib/l in
> fact just subdirectories along with Makefile and README
> Tom
